Crash issues and network issues
(Topic created on: a week ago)
TANMAY_GOR
Hello,
I'm currently using a Samsung S22 Ultra and am facing several problems with my phone, such as network issues and app crashing.
Please fix these issues.
2 Comments
bhghwan
Reset all settings in reset option of settings..will work fine1778291204315.jpg
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● For network issue kindly follow the below steps:
● Kindly check the device in different locations/network coverage areas.
● Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
● Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Kindly try to contact the service provider once.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
