Control panel problem
(Topic created on: 10-11-2025 01:50 AM)
sayyed318
Mere s25 ultra ke control panel me kuch ajib sa hai top side me jo aaj se pehle kabhi nahi showing hua please bataye kya aapke bhi control panel me aisi kich problem hai aur iska solution kya hai
3 Comments
That is smart view (Screen Mirroring) phone ki Screen tv mai dekhne k liya. New nai hai vo.
YOUR_EX
Bro this is not any problem it's option for screen mirroring option, if don't want to use it, u can easily edit nd remove from here.
If u find this is helpful Click on the three dots of my replies right corner nd accept the solution 😊
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the same video clips for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
