Resolved! Solved
Control Panel out of Control
(Topic created on: 05-31-2025 07:13 PM)
Riyan78979
Things don't seem to be good.
Samsung can you please allow us to go back to the good old optimised one ui 6.1.
Resolved!
18 Comments
akhilS24
OS15
Bruh🤣🤣🤣
MrRupesh
how is it possible 😁😁
Mani4
it is beta or stable?
Riyan78979
Stable
Device S23FE
Mani4
please clear cache partition, if not works then format the device after backup
Riyan78979
After the update I had factory reset the device and I found it as a hassle to store data again in same manner as before so not doing that and cache partition I did but didn't helped me.
It's not only me a few others are also facing similar problem on reddit
Mani4
Please file a complaint with Samsung customer support through the Samsung Members App, including the error report and log files related to this issue. Then, wait for the next update, as the Samsung team may address the problem soon. If you'd like, you can mark this as a solution, which will also help other users. To do so, click the three dots in my reply section and select "Accept Solution." Thank you!
KunteAmith
One of the main culprits of various glitches in Samsung's major updates are downloading them on mobile data rather on a stable wifi connection with good speed. This most of the time when ever connection is interrupted some package files are not properly downloaded and when same thing gets installed without checking various issues pop up.
If you have knowledge about flashing OS from PC then go to sammobile.com look for your device model and download update package from there to flash using Odin. That should solve the issue, again for this method also download via a stable wifi connection.
Visiting service center will also solve your issue but the download they will wipe the device memory completely.
Hope this helps you get a solution to your issue.
