05-26-2024 12:02 AM in
Galaxy S- Mark as New
05-26-2024 07:30 AM in
05-26-2024 12:01 PM in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. Kindly perform the following steps to resolve your issue by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
05-26-2024 03:27 PM in
Galaxy SI am very premium coustmers of samsung for more than 20 years but i am giving this in writing .i with my s22 ultra upated software after mobile setup till 100 % when optimisng finished when switch on the phone green line came after line i shut down the phone 2-3 times and it was biggest fault that i upaded my phone dont parchese samsung S seris phone
Dont update one UI version 6.1
05-28-2024 09:49 PM in
