Showing results forΒ
Search instead forΒ
Did you mean:Β
Compare s23 ultra vs. s24 ultra battery πŸ”‹ life is not enough a day.
(Topic created on: 02-19-2024 10:08 PM)
Anvar_
Earlier, I was using the S23 Ultra and I was getting good battery life. Now i updated to s24 ultra and I am not satisfied with the battery life of my new S24 Ultra.
I am confused about why this is happening. Is anyone else facing the same issue?
12 Comments
Arbs974
Beginner Level 5
Same here :( also this AOD is eating more battery
Anvar_
Did you find any solution?
Leigh_A
Takes time to adjust to your usage. Battery life will be better after a week.
Anvar_
We have more usage thats why we are using this device otherwise we can go for any smaller and middle options phones right?
Akiwan
2 weeks needed for the phone to know your usage pattern and this could result high temperature and battery drain, after that your phone will get back to the normal.
Do not be afraid, for me now the phone is enaugh for 3 days and i am heavy user.
Anvar_
Omg 😲 I'm wondered πŸ€”
If we are using only for whatsapp and Instagram battery is there for a normal day
But for other apps nd camera
Its deducted more
calaway
That's not true..battery life of s24 ultra is definitely better than their predecessors
Anvar_
Still, I have both devices, brother. I don't want to lie.
I'm a customer of Samsung with a premium phone. Others are also facing the same issue, dear.
ahmedyaso
For me, battery life is not to much good on s24 ultra is it because i used smart switch to move the apps form my old device or too many apps installed?
