Resolved! Solved
Code won't work.
(Topic created on: 01-26-2024 04:03 PM)
Aculite_29
The codes like *#0*# for self diagnostic and codes like *#06# for imei number are not working on my device.
Is there any way to enable it ?
goodthings
Please go to setting, click security and privacy and click Auto Blocker then turn off Auto Blocker immediately then try to it's again it's working properly. Thanks.
6 Comments
goodthings
Aculite_29
Turing off autoblocker may hamper the security of the device ?
goodthings
Please after use your code again turn on it's. When uses any code first turn off Auto Blocker and after use code again turn on it's. If you like please accept as a solution, it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
FF75
Yup that will do
goodthings
Thanks and your's most welcome.
cs_member10
Dear Samsung Member,
As per checking your issue has been already resolved, if you have any further queries kindly feel free to get in touch with us.
