Charging issue
(Topic created on: 02-09-2024 03:18 AM)
Hammadkhal1d
I got the phone on 6 Feb 2024 and I want to share something I purchased
portronics adapto 70 it is 33w pd charger I m using s23 base it is not charging fastly at first when I plug the charger it shows super fast charging then after 3 secs it disappeared my phone is currently 28% it shows it takes 59 mins to full charge kindly help
6 Comments
love4chat
Use samsung 25 watt charger for super fast charging
AGalaxyuser
Use official 25w pd adapter otherwise your battery will degrade soon.
Jeevas23Ultra
Official 45 watt is also fine for s23 ultra
cs_member10
Dear Samsung Member,
As per your query, we want to suggest you kindly use a ''Genuine Samsung charger'' with your device, If you are using a non-genuine Samsung charger, check the device charging by using another Samsung genuine charger. (If available)
Note: We always recommend using a genuine Samsung charger for charging your device.
If the issue persists with the original Samsung charger then kindly feel free to get in touch with us.
Hammadkhal1d
I got the charger before a week it takes more than a hour to charge using 25 watt samsung charger
Can I use other brand like ptron or potronic adapter for Samsung s23 fe
