05-19-2024 03:17 AM in
Galaxy S- Mark as New
05-19-2024 07:01 AM (Last edited 05-19-2024 07:02 AM ) in
Galaxy SThen check Phone temperature
& Then check it whether your phone charging start or not
If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
05-19-2024 10:41 AM in
05-19-2024 10:56 AM in
05-19-2024 08:23 AM in
05-19-2024 10:34 AM in
05-19-2024 04:16 PM in
Galaxy SDear Samsung Member,
As per your concern, kindly perform the following steps to resolve your Galaxy device moisture issue.
Devices with a waterproof rating of IP68 and above (most of the Galaxy series) are equipped with a moisture detection sensor to prevent water damage to the device. If moisture is detected in the USB port, an error message will be displayed and charging will stop.
In this case, unplug your device from the charger, then wipe with a dry cloth or gently shake your device (5-10 times) with the port facing downwards to release any excess moisture. Place your phone on a cloth in a well-ventilated area, or dry it with a fan.
Does your device display the water drop icon even though it is completely dry and free of moisture?
If you experience issues with charging even after drying your device, try clearing your USB cache. This should resolve your system error.
Settings> Apps> Filter and Sort> Move the switch to the right to enable Show system apps> OK> USB Settings and Storage> Clear cache located on the bottom right-hand corner of the screen to clear your USB cache.
06-17-2024 10:02 PM in
06-17-2024 10:20 PM in
