Charging became very slow and Hearing a harsh/ digital noise while making calls in S22 Ultra
(Topic created on: 04-12-2022 07:34 PM)
JobinJohn
I use my s22 ultra with 24W charging. It was fast enough in the first few weeks and for the last couple of weeks , When i connect it to the charger (25W) it shows 40mins to 100% and even after 40Mins it will show 23mins left. Same when battery protection is ON/OFF.
Another issue is that, When I make phone calls it gives an SHHH / digital noise sometimes in the begenning and I have to switch back and forth to speaker and earpice to get rid of it. ALso I tried Reeset all settings and issue was gone for 3-4days and is back now. Need urgent support for this.
7 Comments
UserAdik
Go to Get help section in Samsung Members app Scroll down select error reports also send your log files and tell the what happened.
Never use your phone while charging .....Turned off Data while charging will solve your problem.
JobinJohn
It was totally fine even when the data was ON. Should I switch off WiFi as well?
tr91
It might be a problem with power supply also. Download ampere app and see whether the correct voltage is getting into the mobile from charger
Dina635
I am using S22 plus and mine is 15 days old and even I am having issue with phone calls .gurgling noise whenever I call someone ,had to put it on speaker and then again to earpiece .Did you get any help on this
Prashanth
Even i am getting the same noise and this happens only on outgoing calls. If you need a immediate relief from the sshh sound, pls switch on the loudspeaker and switch it off. But Samsung is addressing this issue
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask questions).
