Battery issue
(Topic created on: 04-12-2022 07:57 PM)
ashish_piklu
Please fix the battery drain issue in S22 please push some updates for fixing the issue it's a huge difficulties to run this for 10 to 12 hrs it's not possible to carry power bank all the time. Please do something Samsung
8 Comments
SM-G781U1/DS
How to get update one ui 4.1.
ashish_piklu
In my phone s22 it's get the one ui 4.1 out of the box hope you also get the updates soon
My phone model s20fe single sim version
ashish_piklu
Ok hope you also get the updates soon you also check with your model no. Is that device eligible for the latest version of updates or not...
How to check that?
AYush2313
Same on my S20 getting mostly 4Hours of SOT
ashish_piklu
Very pathetic
cs_member8
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
