08-31-2026 02:52 PM in
Galaxy S- Mark as New
a month ago in
Galaxy SDear Samsung Member,
We regret to hear about your experience with our product. We would request you to kindly perform the following steps to resolve your issue.
● If you are using a non-genuine Samsung charger, check the device charging by using another Samsung genuine charger. However, we do not recommend using any slow charger for charging Samsung devices. So, Kindly use a genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Check charger functionality with a different device or try to charge the same device with a different charger.
● If the rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using a normal socket: As a safety measure Fast charging may not support, you while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device Care from settings > Battery > Please tap on three dots (more options) at the top right-hand side > Please select settings > Enable fast cable charging.
For Android 11: Kindly open Device Care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device.
● When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
a month ago in
