Charging Issue on S23 FE – One-Side Super Fast Charging + Unstable Connecti
(Topic created on: 07-30-2025 09:31 PM)
Broski07
Beginner Level 4
I've been using a Galaxy S23 FE with the original 25W Samsung charger and cable.
Until recently, everything worked fine. But since yesterday, I’ve been facing two issues:
1. One-sided super fast charging:
When I insert the USB-C cable one way, the phone shows “Super Fast Charging.” But when I flip the cable and plug it in the other orientation, charging becomes extremely slowor doesn’t register at all.
2. Inconsistent connection:
Very often, even when the charger is connected and plugged in properly, nothing shows up on the phone. I have to connect and disconnect it a few times before the phone starts charging. And even then, it keeps disconnecting on its own randomly during charging.
6 Comments
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung member,
1. Check connectivity & charger functionality:
Please check whether the charger cable and adapter is fixed well.
Remove charging cable and reconnect with mobile phone properly.
Check the charger functionality with a different device or try to charge the same device with a different charger.
Note: We recommend our customers to use only Samsung approved chargers, as 3rd party chargers with different output rating may cause errors in the device.
2. If the device charging with different charger, then kindly check the physical condition of your charger for any damage.
3. Please charge the device in switched off condition for 10 minutes.
For devices with removal battery, kindly remove the back panel of your device and check the physical condition (Bulge, Swelling or visible damage). If the physical condition is not good please do not try to charge or tamper the battery also request you to visit the service center immediately.
4. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
5. If the issue is still not been resolved, Reset the device:
IMPORTANT:
Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Remember google password before resetting the device because it is required during initial setup.
If you do not remember it, then reset, (Forgot password) your google account.
For this:
Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
I am facing the same problem with 25 watt original charger that i recently ordered from samsung shop with my samsung f16 5g using with in box cable,you can view my recent post for more detail
Su_Jaan
Bhai mere s23 phone me bhi
ajeankya
Did you get the resolution?
