Resolved! Solved
Cellular Network problem
(Topic created on: 01-20-2025 10:52 PM)
George_sohan
I am facing sudden 2G net drop while in whatsapp/messenger calls. What is the issue here or is there any ways to get rid of it?
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device internet issue: https://www.samsung.com/in/support/mobile-devices/how-to-troubleshoot-mobile-data-issues/
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
