Can we use 25 or 45 watt samsung charger for s9 plus
(Topic created on: 03-05-2020 03:34 PM)
yash1946
Can we use 25 or 45 watt samsung charger for s9 plus.
6 Comments
SliceSupport
whatever maximum you do use device will charge its battery using only max 15 watt
it does not matter you have a 25 watt or 100 watt .
sbera
No
Muzeeb
only use 15 watt fast recharge
Not applicable
yes
Sahilj1
nope the maximum it can handle is 15w
immi007
you could use it but it only charges at 15 watt max.
