05-11-2025 10:09 PM in
Galaxy SSolved! Go to Solution.
05-12-2025 10:20 AM in
Galaxy SDear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
05-11-2025 10:36 PM in
05-12-2025 08:13 PM in
Galaxy S- Mark as New
05-13-2025 12:41 AM in
