Camera quality / screen hang and over flow sometimes
(Topic created on: 10-02-2025 03:15 AM)
Pawanvishv
I’ve noticed several issues with the device:
1. Camera Quality: The camera performance is worse than my previous phone. Images sometimes appear grainy, and low-light performance is particularly poor.
2. Screen Performance: The screen occasionally hangs or becomes unresponsive, affecting smooth usage.
3. Overflow/Display Glitches: At times, content overflows or does not render properly, which impacts usability.
Overall, these issues significantly affect the daily experience, and I hope they can be addressed in a future update. #camera #screen #s25ultra
3 Comments
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
