Camera problem
(Topic created on: 3 weeks ago)
naiem3900
Camera encountering problem while using 0.06x lens in both still and video..any solution..?
11 Comments
cs_member10
Dear Samsung Member,
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
naiem3900
Tried all these option but all in vain
