Camera problem
(Topic created on: 02-18-2025 08:05 AM)
rajveerchoudhary
S22 ultra ka camera 10x zoom ke baad Mai blur ho rha hai focus hi nhi kar rha hai . Kya problem hai hai koi bta sakta hai
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
