Camera problem in pro mods after change the camera satting
(Topic created on: 3 weeks ago)
shubhh00100
Way the camera screen is flipped after change any camera satting and goodlock camera assistant sattings after reset the satting camera work fine plz give me any solution and tell me anybody face the same problem
4 Comments
shubhh00100
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
