Camera problem, camera failed
(Topic created on: 11-09-2025 06:17 PM)
rushiljamod
In s23 fe camera failed problem, in video call front camera working back camera not working and in camera app both camera not working and warning show camera failed how can I fix that bug .
7 Comments
goodthings
Kindly reset factory data with backup then try to it's again. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
vinayshah
Expert Level 4
@goodthings bhugg madarhcod bhenhcod bsdke rndi sle
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
● Clear camera application data: Apps>Camera>Storage>Clear Data.
● Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications.
● You can reset your device by following the steps:
3. If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
rushiljamod
I try all the step even i reset my phone but still camera issue was not solve .
PoovarasanDp
Myself also Samsung A54 after update camera not working showing Camera failed
chkcherokee
What do should be done for dis issue
