08-26-2025 09:49 AM in
Galaxy S- Mark as New
08-26-2025 10:54 AM in
08-26-2025 11:35 AM in
Galaxy S1) clear cache and data of camera app
2) most likely its HW issue. Better visit service center while its in warranty period. Also before u visit, take pics and video of ur phone in front of the service center guy so that post servicing if there's any dispute, u can hold them responsible.
08-26-2025 04:13 PM in
Galaxy SDear Samsung Member,
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Keep your apps updated: Galaxy Store apps: Open Galaxy Store, tap the Menu (the three horizontal lines), in the upper left corner, and then tap Updates. From here, you can either tap the circling arrow next to individual apps to update one at a time or tap Update All to install all available updates.
Play Store apps: Open the Play Store, tap, and then tap your profile picture. Tap My apps & games. From here, you can either tap Update next to individual apps or tap Update All to install all available updates.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
