Resolved! Solved
Camera issue in s23
(Topic created on: 10-09-2024 09:40 PM)
Ashu9810
Camera has gone worse pictures are softened and picture quality is worst
Resolved!
11 Comments
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that Samsung has found an issue where camera images may be affected at specific zoom levels when using the 'Maximum' option in Intelligent Optimization. A software patch is has developed to address this issue, so it's important to keep your device's software updated. However, we would request you to please update your device in leteset softwere update, In case your device not get update notification yet, kindly wait for update and your issue will resolved after updating the device.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appriopriate issue category> Type your query and send.)
Ashu9810
All thing done
