Camera focus issue S24 Ultra
(Topic created on: 11-26-2024 03:31 PM)
NiteshIndia
Hello everyone,
Anyone noted the camera focus issue in S24 Ultra while capturing photos? In the same image, left top portion looks unfocused while middle portion looks properly focussed. It is happening in every image. Even while using document scanner, generated pdf / jpg has same issue.
3 Comments
Milan
Same thing happening on s23 ultra too. Lagta hai samsung phone ke sath brand ka bhi focus abhi blur ho gaya hai.
cs_member10
Dear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
NiteshIndia
Sir, why should I do all these things when the entire lineup of S24 ultra is facing same issue. You can kindly check at your end and try to resolve the issue in software update.
