Calling issue. When i make a call there is 5 or 7 delay.
(Topic created on: 06-22-2018 01:13 PM)
LZ
When i make a call there is 5 or 7 second delay in dialling the call, and showing "conditional call forwarding is active" can u please help to solve this issue.
2 Comments
jaaduh
first disable the call forwarding on ur network, if its not imp.
update your phone dialer app.
it the problem still persists, then try to reset ur fone.
admin_
We do apologize for the inconvenience caused, to fix the phone dialer issue please follow the below steps:
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Show system apps >> Phone >>Storage >> clear data.
- Please run your device in safe mode.
- If still issue persists, the relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
The pop up appearing "conditional call forwarding is active" is from the network side and you need to contact the network service provider regarding this.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
