Call recording symbol not going away
(Topic created on: 10-17-2024 02:57 PM)
anilgireddy
I deleted a call recording, but the call recording symbol in the recent call history is not going away.
8 Comments
sameco
Can you send screenshot?
anilgireddy
I already deleted this call recording, but not the going concern symbol.1729159524710.jpg
sameco
What device are you using? I have tried this and in my phone (M34 ) the symbol goes away if I delete the recording. If you don't want to record every call then you can change your settings to record only calls from unknown numbers in the future. Right now , I am not sure why this symbol is not going away.
boywidlens_
History is History you can't erase everything
anilgireddy
The other mobile symbol is going.
Bro ....try deleting cashe for the caller/dialer app.
anilgireddy
Tried but no use
cs_member10
Dear Samsung Member,
● Clear app cache through Device care:
→ Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
→ Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
