Call problem
(Topic created on: 11-17-2025 05:45 AM)
PiyasBaidya
After the latest update on Samsung S24, my Grameenphone SIM can’t make or receive calls, only data works.”
3 Comments
goodthings
Kindly complaint to Samsung customer care support through Samsung Members App as a error report also send log files along with this error report for this issue and wait for next update it's maybe fix it by Samsung team soon. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that it can happens due to network glitch. Meanwhile, kindly perform the following steps to resolve your issue by the given link:
● Unable to make call issue: https://www.samsung.com/in/support/mobile-devices/what-to-do-when-your-galaxy-device-is-unable-to-ma...
3. If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
