Call problem
(Topic created on: 09-24-2025 09:10 PM)
NIGHTMARE01
There is issue in call during the call the call is not clear and some noise too just like broken speaker after recieve one ui
8.0
Please fix this problem in s25
cs_member10
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
