Call connect problem
(Topic created on: 05-29-2017 07:59 PM)
akshit11
everyday there is a problem when i call someone.......i have 2 sims jio and airtel.....i try differently one by one with both the sims that call does not connect....then i use to restart for making a call
6 Comments
subodhsg
same here
akshit11
what to do now
subodhsg
report error
Jakka
First of all, there are so many issues with Jio network especially in connecting calls
admin_
"Thanks for being with Samsung and for sharing your.
Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. We would like to suggest you kindly follow the below mention steps to overcome the Issue:-
1) Ensure that network frequency of your device should be selected on Auto-mode.
Menu>Settings> Connections>More Networks> Mobile Networks> Network Mode> Select Auto mode (GSM/WCDMA/LTE).
2) Search for the Network Manually as follows:
Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search.
3) You may check by exchanging the SIM in SIM slots.
4) Insert different SIM card in your mobile and check if the issue is resolved or not.
If still issue persists then we would suggest you to once contact with your service provider".
SM17
same here
