Cable for 65w adapter
(Topic created on: 05-25-2024 12:10 PM)
abhijeetsinghraaj
Hi, if anyone is using 65w Samsun adapter can suggest which 100w cable to use for 45w charging. I have bought one but it's not showing super-fast charge 2.0 on s23 ultra
9 Comments
JOmobile
Cable and adapter compatibility issue.use authorized cable.
There's no authorised 100w cable available on the Samsung store.
Haazim
You need 100w cable to support fast charging 2.0. You can buy Samsung original cable (100w) or Belkin 100w or Ugreen which are all good but make sure you buy 100w.
You can check out following also::
https://amzn.in/d/baIoevh
goodthings
Kindly use only original Samsung adapter and cable. Thanks.
I'm using original Samsung compatible charger. It's not my fault they aren't giving 100w cable and not supporting the other 100w cable which aren't local
Members_Fki4GOb
I have been using Duracell 5A cable with the 65w adapter. This cable is a bit thick, but superfast 2.0 working fine.
https://amzn.in/d/16umSBr
I ain't sure about its durability, but for the time being it does its job well.
In case if you are particular about using samsung cable, purchase a samsung 45w adaptor along with the cable. It comes with a 100w cable.
I have enquired service center as well as available shops for samsung authentic 100w supporting cable individually, but sadly it isn't available.
Not even 45w adapter is available online. It's out of stock. I don't know what's wrong with Samsung. That's so annoying that you can't buy Samsung's 5A cable. I have heard the charger is too heavy and big considering even 65w chargers are so compact and light nowadays. Samsung ain't working on such things. They should literally provide 5A cable out of the box. I wished I would have stuck to the regular s23
Defender130X
Use 5Amp cable..its a long 1.8m..
Not available anywhere. Not even online
