Brightness issue while using camera in sunlight
(Topic created on: 07-16-2024 08:05 PM)
OmniMan
Beginner Level 5
Hey guys.
I have been facing this issue since I bought this device S24 ultra back in January. Whenever I open camera in sunlight, The phone heats excessively and display gets so dimmed that I cannot see anything in day light. Does anybody know the solution of this issue?
9 Comments
mhdmuneeeeb
Please Report this issue to Samsung Help ASAP
Oldy47
There is work around .
Install Good Guardians modules in that I don't remember exactly which one but try Thermal/Battery guardian .One of them have a brightness related setting as per your issue .
If you can't install upper modules from Galaxy store try with fine lock from playstore .
Also you firstly need to install goodlock and
Good Guardians , GG Agent to run those modules mentioned above.
Tell me this works or not.
OmniMan
Beginner Level 5
Thanks, will try that
naddamithun
I tried, it's of no use
Oldy47
Well then you can only hope for samsung to solve this by pushing OTA update .
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
naddamithun
Have u found any solution
OmniMan
Beginner Level 5
Not yet. I'm thinking about vising samsung care to see if they know how to solve it.
naddamithun
Does your dimming display problem solved ??
