Bluetooth problem
(Topic created on: 07-02-2025 07:47 PM)
deadalive
Beginner Level 4
My phone's Bluetooth is not connecting with the laptop and after restarting and removing still im facing this problem.
6 Comments
goodthings
Please reset Bluetooth and WiFi settings also reset all settings in general management settings also flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually also update your's all apps then try to It's again. If you like Please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
deadalive
Beginner Level 4
Thanks for the comment but not worked
goodthings
Kindly complaint to Samsung customer support through Samsung members app as error report also send log files along with this error report for this issue and go to service center for check and resolve this issue. If you like Please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome.
cs_member10
Dear Samsung member,
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Kindly try to connect your device with "other devices" and check.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● The clear cache memory of a particular application: Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
3. If you do not remember, then reset (Forgot password) your Google account.
