Bluetooth problem
(Topic created on: 05-30-2024 04:20 PM)
Sabhari
I can't able to connect my bluetooth device to another phone, they can't also able to connect to my S23 ,I've tried reset my bluetooth settings and cleared the cache also still it's not working. But it's only connecting with earbuds.
cs_member10
Dear Samsung member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Reset app preferences: Settings > Apps > More option > Reset App Preferences.
Kindly try to connect your device with "other devices" and check.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset settings: Settings>General Management>Reset> Reset all settings to their default.
Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
