01-07-2025 01:55 PM in
Galaxy S- Mark as New
01-07-2025 02:58 PM in
01-07-2025 03:01 PM in
Galaxy S- *Restart Your Device*: Sometimes, a simple reboot can resolve connectivity issues. Turn your Samsung Galaxy S24 FE off, reboot it, and check if the problem is solved.
- *Toggle Bluetooth On and Off*: Slide two fingers downwards from the top of the screen, press the Bluetooth icon to turn it off, and then turn it back on.
- *Check Bluetooth Visibility*: Ensure your phone is visible to all Bluetooth devices. You can do this by going to Settings > Connections > Bluetooth > Visibility timeout.
- *Clear Bluetooth Cache*: Go to Settings > Apps > Bluetooth > Storage > Clear cache.
- *Reset Network Settings*: Go to Settings > General management > Reset > Reset network settings.
If none of these steps work, you may want to consult your car's manual or contact the manufacturer's support team to ensure that the car's Bluetooth system is compatible with your Samsung Galaxy S24 FE model.
Please do check these links
https://www.t-mobile.com/support/tutorials/device/samsung/galaxy-s24-fe/troubleshooter/troubleshooti...
https://deviceguides.vodafone.co.uk/samsung/galaxy-s24-fe-android-14/troubleshooting/connectivity/a-...
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-08-2025 08:35 AM in
Galaxy SDear Samsung member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Step 1: Check your vehicle.
1. Check your vehicle whether the vehicle or stereo is compatible with Android Auto.
2. Make sure that Android Auto is switched on in your vehicle's settings.
3. On some vehicles, Android Auto support was added in an update.
4. If your vehicle is listed as a supported model but Android Auto isn't working, try updating your infotainment system or visit your local dealer. Consult your vehicle manual or manufacturer if you need further assistance with it.
Step 2. Check your phone: -
1. If your phone is running Android 10, no need to download Android Auto separately.
2. If your phone is running Android 9 or lower, you need to download Android Auto from the Play Store.
3. Your phone connection must allow data transfers for Android Auto to function.
4. When your device is connected via a USB cable, swipe down from the top of the screen and tap the notification from the Android system. Select the option that allows for file transfer.
Step 3. Connect and start: -
1. The connection between Android Auto and the vehicle is possible using a Bluetooth or USB cable, and the connection method may differ depending on the vehicle and manufacturer.
2. Check if Android Auto is displayed on the display.
3. While most USB cables look similar, there can be huge differences in terms of their quality and charging speeds.
4. Android Auto requires a high-quality USB cable that is capable of supporting data transfers. If possible, use the original cable.
5. Android Auto requires a high-quality USB cable that is capable of supporting data transfers. If possible, use the original cable that came with your device.
Checklist when unable to connect Android Auto: -
1. Android Auto recommends Android 6.0 or higher.
2. Check for updates related to Android Auto, and always keep the app up to date.
3. For the sake of safety, the initial connection is possible only when the vehicle is stopped.
4. The connection between Android Auto and the vehicle is possible using
5. The connection between Android Auto and the vehicle is possible using a Bluetooth or USB cable, and the connection method may differ depending on the vehicle and manufacturer. The exact connection method between the owned vehicle and Android Auto needs to be confirmed by the vehicle manufacturer.
4. Use Samsung's genuine USB cable (Depending on the vehicle, even a genuine cable may not be compatible) Additionally, it is recommended to use a short USB cable within 1m.
5. Check if you are connected to another vehicle.
Step 1. Unplug your phone from the car.
Step 2. Open the Android Auto app on your phone.
Step 3. Select Menu > Settings > Connected cars.
Step 4. Uncheck the box next to the Add new cars to Android Auto setting.
Step 5. Try plugging your phone into the car again.
If your issue is not resolved after performing the steps, we would request you kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
