04-11-2025 10:45 AM in
Galaxy S- Mark as New
04-11-2025 10:50 AM in
04-12-2025 09:38 AM in
Galaxy SDear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
Kindly check the same headphones with another phone or other headphones/ buds with the same mobile, if still facing issues, please visit the service center for a physical inspection of your device and headphones. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
