Bluetooth headphone issue.
(Topic created on: 03-03-2025 10:44 PM)
MdAzmainAdil
Recently, I've been having an issue with my Bluetooth headphones paired with my S21. I have three different headphones paired with it. Right after installing the new software update in January, all my headphones started acting up. The issues I'm facing are:
 * Auto-disconnecting and reconnecting.
 * Distortion in audio and video calls.
 * Occasionally, voice call issues get resolved, but then the audio from the media player becomes fuzzy, or sometimes there's no response.
Now, I've checked my headphones with other devices and confirmed that they are working correctly. I've unpaired and re-paired the headphones several times, but that hasn't solved the issue.
2 Comments
cs_member10
Dear Samsung member,
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Kindly try to connect your device with "other devices" and check.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
MdAzmainAdil
Thank you for your feedback. While a device reset was not feasible, a system update released on March 8th appears to have resolved the reported issue.
