Bluetooth auto connect and retain issues in Galaxy S8
(Topic created on: 09-01-2017 02:08 PM)
omkarg81
S8 device most often doesn't auto connect to an already paired device and when there is a need for bluetooth connection to be established the phone needs to be again used for manually establishing the connection. All the other S devices I have used never had this problem. Needs a fix in OTA update.
4 Comments
Farhu007
S8 device most often doesn't auto connect to an already paired device and when there is a need for bluetooth connection to be established the phone needs to be again used for manually establishing the connection. All the other S devices I have used never had this problem. Needs a fix in OTA update.what is reason?
khans25ultra
my s8 plus auto connect
i dnt have any issue
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
omkarg81
I have done in there. Thanks
