Bluetooth active icon not showing on top right side
(Topic created on: 05-21-2025 06:14 PM)
Kaillas
Hello Community Members,
Why I'm not viewing Bluetooth active on top right hand side when I connected to Bluetooth.
Currently I'm using Samsung S25 device
Pls advice.
2 Comments
Alunika
I advice that you can find a solution on smart tutor app of Samsung, i have not used but it may solve your problem
cs_member10
Dear Samsung member,
We would like to inform you about an update regarding the Bluetooth connectivity feature on your device. Following the recent updates, please note that the Bluetooth connected symbol will no longer be displayed on the status bar.
However, you can still see if your device is connected via Bluetooth by swiping down the quick panel. This will provide you with the necessary information about connected devices.
If you have any questions or need further assistance, feel free to reach out.
