04-11-2025 02:33 PM in
Galaxy S- Mark as New
04-14-2025 12:39 PM in
Galaxy SWe’re truly sorry to hear about the inconvenience you’re experiencing, you may try the following steps to troubleshoot the issue.
1. Clear the cache for both apps:
-Go to Settings > Apps
-Select the app
-Tap Storage
-Tap Clear Cache
2. Try resetting Wi-Fi and Bluetooth settings:
-Go to Settings > General Management > Reset
-Tap Reset Wi-Fi and Bluetooth settings
-Review the information, then tap Reset settings
Note: There is no confirmation prompt — once you tap Reset settings, the reset will occur immediately. You will need to reconnect to your Wi-Fi network and Bluetooth devices afterward.
If the issue persists, please send an error report, and you will get a response from the experts in this field, through the Samsung Members application
1-Launch the Samsung Members application on your device.
2-Go to "Support", scroll down, and select "Send Feedback".
3-Select Send error report
4-Select the appropriate category for your issue.
5-Make sure to select "Send System Log Data" to facilitate quick resolution. Please describe your issue in detail.
6-Adjust the frequency settings to your preference.
7-After submitting, you will receive a notification of the response from Samsung shortly.
