05-06-2025 07:44 PM in
Galaxy S- Mark as New
05-08-2025 07:39 AM in
05-08-2025 07:47 AM in
Galaxy SPlease note that after a software update, the battery may take some time to adapt to the new system changes and usage patterns. This is normal, and performance typically stabilizes within a few days as the device optimizes background processes.
You may try the below steps that may assist you.
1. Clear Cache: Go to Settings > Apps > One UI Home > Storage > Clear Cache.
2. Update Software: Ensure your device is running the latest software version by going to Settings > Software Update > Download and Install.
3. Disable Unnecessary Features: Check for any unused features or widgets that may be consuming battery.
4. Force reboots your device by pressing and holding the power and volume down buttons simultaneously for more than 7 seconds and your device will reboot.
