Battery
(Topic created on: 02-28-2024 08:05 AM)
Rohit9981
Battery draining fast on my S23ULTRA after Feb update
5 Comments
Mayur000
Stop AI features, Disable Bixby, Google Search.
Also check background running apps, put then onto deep sleep mode.
Disable 5G, Use 4g.
Disable location wifi Bluetooth printer.
Disable always on display and
Always on finger print sensor.
Sam-Noor
How much SOT time you are getting in s23 ultra. If you are getting in between 6.5h to 7.5h than its good depends upon the live of device.
Sam-Noor
I am getting almost 7h of SOT time even 1 year old device. 1709093158006_1709093157999_0.jpg
goodthings
Please stop adaptive brightness, remove unused apps also put unused apps deep sleep or sleep mode, turn off location when necessary open than close, stop background apps, use dark mode, use 60 Hz. Also complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
cs_member8
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
