11-07-2024 08:02 AM in
Galaxy S- Mark as New
11-07-2024 08:18 AM in
11-07-2024 08:36 AM in
11-07-2024 05:10 PM in
11-07-2024 08:49 AM in
11-07-2024 05:12 PM in
11-07-2024 07:33 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
