Battery protection
(Topic created on: 02-28-2023 02:20 PM)
Faisal01
Why this much fast battery drain when 85% charging mode is on samsung should optimise this mode
8 Comments
Battery protection has nothing to do with battery drain.
It's a feature that stop charging at 85% to longer the battery life.
For battery drain check if any background applications is active.
As I can see you re using wifi and Bluetooth. That might cause this battery drain.
Faisal01
But wifi and Bluetooth are necessary things
joel_subash
Battery protect has nothing to do with battery dain but you can try some tricks extend and protect battery check it out :- https://r2.community.samsung.com/t5/Tech-Talk/Some-powerfull-battery-saving-tips-used-by-Modes-and-R...
Faisal01
I have tried all these things but when we shift from thode apps then there is gerk in fps 120 to 60 so its feels like lag if front of my friends and cousins so i dont want insult that my device lags
joel_subash
Disable is feature then Screenshot_20230228_204418_Modes and Routines_1000005123_1677597280.png
Yeah it goes from 85 to 84 in less than a minute
Faisal01
Same
cs-member11
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application>Support>Ask a question/Tap an error report>Type your query>Send)
