Battery issues.
(Topic created on: 12-15-2022 04:12 PM)
kshitizchouhan99
Has anyone been experiencing huge battery draining issues on S20FE 5G after OneUI 5 update ?
I use to charge my device twice in 24 hours and sleep with a handful of 25-30% in the reserve. Now it's around 10% and and sometimes (not everyday) I put my phone on charge 3 times in 24 hours.
14 Comments
Himadri_S
Yup same
Are you considering Yuvinitish option ?
Yuvinithish
I have the same issue after update. I went to service centre and they flashed the software again. Now it becomes normal and now my SOT is 8 hrs and normal idle time 3 days
I can't risk my data.
Sid_Karna
3 days idle time on what model?
Yuvinithish
S20 Fe 5g at ultra power saving mode
EatenCabbge
Ultra? Bruh
Yuvinithish
Yes with limit apps and home screen option ON in power saving mode
Pasho
No i am not experiencing any type of battery draining issue
