12-22-2025 10:36 PM (Last edited 12-22-2025 10:37 PM ) in
Galaxy S- Mark as New
12-22-2025 11:29 PM (Last edited 12-22-2025 11:32 PM ) in
12-23-2025 08:56 AM in
Galaxy SDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
12-23-2025 10:58 AM in
