Battery issue?
(Topic created on: 12-08-2024 05:56 PM)
zigzagzoo
How long are your s24 ultra's lasting because mine only lasts for about 7-7.5 hours screen on time where as my friends who own s24 ultra say they get around 9 to 10 hours
3 Comments
MADY15387
Hamare paas to sirf s24 hai...
24 hr chal jata hai...
Wo kya hai naa...
Naa gf hai, naa hi hai koi game
In sab ko phone me ghusaaoge to battery kahan se paaoge
zigzagzoo
Aree bina game khele 7-8 hours de raha hai
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that Battery life depends on how the battery is used. And it can reduce according the time of usage. If you are facing draining issue, kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
