Battery draining
(Topic created on: 13 hours ago)
Gireeshcrazy
Galaxy S23ultra smart phone battery quick fast draining no using time
Please resolved problem galaxy team..
3 Comments
ChaudharyRavi
There is no Security update post Nov24
Also Battery Drainage is common even after changing modes
Wodehouse
Expert Level 4
Simple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive brightness
4 Disable AOD
5 Enable extra dim
6 Change display to natural
7 Record videos in FHD
8 Restrict gaming to HD or FHD and slower frame rate
9 Switch to dark mode
10 Disable near by device scanning
11 Disable WiFi scanning
12 If 5G is unavailable change network to LTE/3G/2G
13 Allow the battery to drain completely and recharge,say once a month.
14 Enable auto restart
15 Run device care
16 Disable apps running in back ground.
17 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
cs_member10
Dear Samsung Member,
Kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
