Akkizoro
02-20-2025 10:04 PM in
Is anyone facing battery draining issues in S24 ultra. For the past one month my battery is draining off quickly if the screen is locked Any solutions to stop that
6 Comments
RM10
02-20-2025 10:13 PM in
Not in S24 ultra but on S23 fe..from last week I've been noticing unusual battery drain as well...
Today got a security update...hopefully it resolves from it...
Harsha-D
02-20-2025 10:29 PM in
Put unuse app to deep sleep
Akkizoro
02-20-2025 10:30 PM in
Already done i thought bcoz of the game only it is draining but even when I am not playing game it is draining it is annoying
Harsha-D
02-20-2025 10:34 PM in
Check battery usage in device care.you can see which app using more battery
Zishy
02-20-2025 11:15 PM in
change performance mode standard to light performance
WG3
02-21-2025 03:42 AM in
Same problem
