05-19-2025 01:27 AM in
Galaxy S- Mark as New
05-19-2025 01:44 AM in
05-19-2025 09:27 AM in
Galaxy Splease like my post 🙏https://r2.community.samsung.com/t5/Galaxy-Gallery/s24-fe/td-p/19464538?src=ShareByUserCM
05-20-2025 09:54 AM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
05-20-2025 03:02 PM (Last edited 05-20-2025 03:03 PM ) in
Galaxy SBecause,many of us tried troubleshooting steps and it is not possible to reset the device for all of us,cause this is a long way process.
Better you should provide a security update and fix the battery draining issue along with excessive heating issue .
