Battery draining issue seen samsung s21 fe
(Topic created on: 05-17-2024 07:35 AM)
05Leo
Battery draining issue seen in samsung s21 fe after update to one ui 6.1 . Please fix this ASAP
13 Comments
SKANTH95
Beginner Level 4
Yes
Anirburnn
Beginner Level 3
Also magic eraser is missing
Harish_11
No bro go to edit tap 4 dots on the right side bottom to view the magic eraser option
Anirburnn
Beginner Level 3
Thanks man
Janmajaya123
Same with Samsung Galaxy A55
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
fluidpillar
Don't u feel shame to say this always.?.
05Leo
Thanks for supporting from these types of scammer
goodthings
Both of you, you know that after a major update reset factory data with backup is essential for your's device to better performance ?
