Battery draining fast
(Topic created on: a month ago)
SachiQ77
I used to get 7 hours of screen time. After a One UI 7 update, the screen time has been reduced by 20%. Samsung, please fix this as soon as possible.
With subsequent updates, the camera quality has also been reduced. We paid a premium price for premium services; this is unacceptable. If this is not fixed, I will switch to iPhone.
5 Comments
CipherChip
I had same problem, because of major update ,I performed factory reset.
I did the same, my battery is good now , I charged my phone to 100% in morning and my battery still show 63% .
lf you find this useful, then click on the three dots given above this message and accept it as a solution.
ZellyFizzz
wait for fix updates
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
